How to fix photobucket links
- 2guests
Saw this on another forum...thought I share it here.
Go to your post with broken Photobucket links and select "Edit"
Go to the code where you added the pic
It will be everything the [ IMG] and [/IMG ] tags.
[ IMG]http://i1082.photobucket.com/albums/j36 ... G_2411.jpg[/img ]
(spaces added at front and rear of tags to make it non-functional to illustrate code)
Right before the last tag, and after the .jpg add this: ~original
So it looks like this:
[ IMG]http://i1082.photobucket.com/albums/j36 ... g~original[/img ]
Hit preview to verify that you did it correctly, then hit save.
- jreeves47
Re: How to fix photobucket links
awesome! i just fixed a few of mine. thanks!
- chankgeez
Good to know, thanks. I wonder how long it'll take 'em to catch on though.
0
- Blues Bird
thanks for the tip. Will try it out!
- Blues Bird
Blues Bird wrote:thanks for the tip. Will try it out!
Just checked it. Works like a charm.
- rafmax
This post should be on Top of the Board Index !
Thanks
Thanks
Done and done.rafmax wrote:This post should be on Top of the Board Index !![]()
Thanks
- jeni70
- Random Rat
Another trick if you wanna download all your albums in a quick way. It has to do with codes and stuff so you need https://www.sublimetext.com/ but it was easy.
https://gist.github.com/philipjewell/a9 ... 5b06deb13d
"Don't wipe the sweat off your instrument
You need that stink on there. Then you have to get that stink onto your music."
/beefheart
/beefheart
Users browsing this forum: fendersilver and 8 guests
