Design Flaw or Vintage Correct?
- CraigBeckGuitar
Looking for the wisdom of forum members.
I purchased a Fuzz Face replica...hand wired, point to point, top notch construction. The pedal drains the battery to less than 1 volt within 1 month even though no cables are plugged in except during the 1 hour per month of use. This has happened for 3 months in a row.
When I contacted the builder and explained the problem, his reply was "this is normal for vintage type circuits and that I have to understand that it is a handmade pedal. If you leave any electrical device with the batteries in it, and do not use it much, the batteries will drain". His solution was for me to unscrew the back and remove the battery after each use.
I have other Fuzz Face clones from DAM, Pigdog, Blackstrap Electric...each of these has had the same battery for over 1 year.
Has anyone had this issue occur or heard of this issue occurring?
Re: Design Flaw or Vintage Correct?
My guess is it's wired incorrectly so that the battery is always on - not just when the input jack in inserted. Had this issue on an old DeArmond wah, which was wired incorrectly at the switch at the factory. If you post a gut shot I reckon one of our resident builders will spot the problem.
- CraigBeckGuitar
Great idea! Thanks HorseyBoy.HorseyBoy wrote: ↑Mon May 17, 2021 1:09 am My guess is it's wired incorrectly so that the battery is always on - not just when the input jack in inserted. Had this issue on an old DeArmond wah, which was wired incorrectly at the switch at the factory. If you post a gut shot I reckon one of our resident builders will spot the problem.
- Laservampire
- pagan
The input jack socket is the wrong type (mono). It’s just got connections for tip and sleeve, so it’s not connecting and disconnecting the battery. The red (positive) wire from the battery is constantly connected to ground through the two jack sockets, so the battery stays connected.
Instagram @paganfuzz
yep - builder is either an idiot (this is one of the first things you learn) or just ran out of stereo jacks and thought they could get away with it - not a good sign either way.
- Spook
This happened to me too, fortunately the builder took the pedal back an installed stereo jacks at no cost, the pedal did have
9v jack too...so i guess he did not think i would use battery.
Who's the builder ?
Who's the builder ?
Plus he's used fake NKT275 trannies - hope you didn't pay a lot for it.
- CraigBeckGuitar
Even I know that. Builder should be ashamed of himself.pagan wrote: ↑Mon May 17, 2021 4:16 am The input jack socket is the wrong type (mono). It’s just got connections for tip and sleeve, so it’s not connecting and disconnecting the battery. The red (positive) wire from the battery is constantly connected to ground through the two jack sockets, so the battery stays connected.
Users browsing this forum: No registered users and 13 guests
