Page 1 of 1
The hobbyists 'Quick questions' thread
Posted: Thu Jun 08, 2023 12:38 am
by Nick
It feels like every time I have a simple/silly question about pedal (or general) electronics, I'm always hassling the same people for help. Surely there are other newbs like me out there that find themselves in similar predicaments? And maybe by posting our questions in public, we're also doing a favour to our regular helpers by giving them a break?!
I'll get the ball rolling...
I'm troubleshooting an effects unit of mine with a built-in transformer (as opposed to being battery-powered). Are there any extra precautions that I need to take, before measuring the electrolytic capacitors with my LCR meter?
Re: The hobbyists 'Quick questions' thread
Posted: Thu Jun 08, 2023 3:29 pm
by Dr Tony Balls
Nick wrote: ↑Thu Jun 08, 2023 12:38 am
PROBABLY not, but what pedal is it?
In a regular solid state pedal you're taking 120 volts AC (240 in the UK/EU) and the transformer will step down the voltage to something more useful to the pedal, say like 12 volts AC. Then the power gets rectified and filtered to something like 9 volts
DC and that's what's gonna be on the filter caps and supplying the voltage to the pedal circuit. 12 volts or 9 volts wont hurt you. A Univibe runs at like 18v and event that is just fine.
In contrast, a tube amp takes that 120 volts AC (or 240) and the transformer steps up that voltage to something like 600 volts AC, then rectifies it and filters it to something like 450 volts DC that will be sitting on the filter caps. THAT will fuck you up.
So if you have a pedal that is making low voltage supply, there's less to be concerned about. If you have one that's making high voltage for a tube circuit there's more to be cautious of. Regardless i'd always make sure to keep your fingers away from the mains supply going in to the thing because that can zap you.
Posted: Thu Jun 08, 2023 8:23 pm
by Nick
Thanks, Balls! That makes sense to me. It's an Arbiter 'Add-a-sound' box, so no tubes or anything.
Posted: Mon Jun 19, 2023 8:49 pm
by underorbit
Anybody have any idea who made this pickup? For a Stratocaster, measures 5.9, tape seems not original?
https://imgur.com/a/7NiQkxd
Posted: Tue Feb 06, 2024 5:43 pm
by Nick
Is it ever worth replacing the input/output (and circuit in/out) wiring on a Big Muff style pedal with shielded cable? I'm thinking of messing with my vintage Jumbo Tone Bender to see if I can improve its performance (since it's already been worked on by a previous owner in the past).
Posted: Tue Feb 06, 2024 7:49 pm
by Dr Tony Balls
Nick wrote: ↑Tue Feb 06, 2024 5:43 pm
Depends who you ask, I suppose. I have never found benefit in shielding the in/out leads inside the box (for a standard pedal, anyway). The stuff you're shielding against (EMI, high current AC) isnt generally coming from a source inside the pedal so the whole thing is shielded by way of its metal box. But it bears mentioning that folks like Dave and Pete Cornish seem to do it quite a lot if not exclusively.
Posted: Tue Feb 06, 2024 8:20 pm
by Nick
Dr Tony Balls wrote: ↑Tue Feb 06, 2024 7:49 pm
Yeah, I know those guys have been doing it for years, and I assumed it was a kind of 'good practice' thing to do with high-gain pedals. This pedal could be an interesting opportunity to experiment with that. Quite a lot of companies were using shielded cables for fuzz pedals back in the 60s
Posted: Tue Feb 06, 2024 10:10 pm
by Dr Tony Balls
Nick wrote: ↑Tue Feb 06, 2024 8:20 pm
Right, but looking at the vintage stuff, is a Mk1.5 or Vox Bender any quieter than a Fuzz Face? You could always A/B quickly by just connecting and disconnecting the shield and listening.
Posted: Tue Feb 06, 2024 11:42 pm
by sledz
If there is any difference in simple layouts, it must be really small. Using it today is more professional-attitude practice or just for the looks, than necessity. It may be obligatory when you route sensitive signals close to 'dirty' circuits like clocks; in fuzz maybe situation when input and output wires need (for space reason) to be routed very close together. Some wires may be microphonic though (usual suspect is teflon, but also I had very good quality PVC wire being microphonic), it's easy to hear with gain cranked and knocking that wire with finger or whatever.
