Page 1 of 1
Someone clever help me with my DIY A/B box please!
Posted: Wed May 27, 2009 11:20 pm
by smogfalls
Yo,
I just built myself a little A/B switch with LED's and a power tap. I simply copied the one on the Fulltone site...
http://www.fulltone.com/PDfFiles/AB_switcher.pdf
Anyway, it works great unpowered (but this means no LED's), but as soon as I power it, it still works but it becomes quite noisey.
I'm no expert so it'd be great to get some advice on what might be going on here.
Thanks so much,
Xan :)
Re: Someone clever help me with my DIY A/B box please!
Posted: Thu May 28, 2009 1:55 am
by sir h c
You do have the 2.2k resistors in there right?
Posted: Thu May 28, 2009 2:23 pm
by fuzzer
Hey, in that pic it looks as if the jacks' tip connections are touching the resistor leads.
Check that.
Also, ¿What are you using to power that box?
Posted: Thu May 28, 2009 4:06 pm
by smogfalls
cheers for the input, I checked the resistor leads and they aren't touching anything, it does look like they are in the picture but they are a decent distance higher than the 1/4" jack.
Someone over on TGP suggested that the cloth wire might be an issue, is this possible? It's the only stuff I had lying around and didn't really put much thought into using it!
And to power the box I'm using a T-Rex Fuel Tank Jr.
Cheers,
Xan :)
Posted: Thu May 28, 2009 6:25 pm
by imlikeajungle
To rule out the PS you can connect a battery clip and check whether that solves the problem.
If not, I would reheat all connections - worst case scenario quickly rebuild. A lot of the time, that goes quicker
Posted: Thu May 28, 2009 9:19 pm
by fuzzer
hmm, the test suggested is good but I don't think the PS is the culprit, because that Fueltank is a very good source.
Posted: Thu May 28, 2009 9:22 pm
by fuzzer
smogfalls wrote:Someone over on TGP suggested that the cloth wire might be an issue, is this possible?
Hmmm, I don't think so, it would give you trouble even with the PS disconnected.
Posted: Thu May 28, 2009 9:50 pm
by SonicVI
Try sticking a large electrolytic cap (100uF maybe) across the power jack.
Posted: Fri May 29, 2009 2:07 am
by fuzzer
SonicVI wrote:Try sticking a large electrolytic cap (100uF maybe) across the power jack.
That and a small plastic cap (0.1 - 0.33 [uF]).
Posted: Sun May 31, 2009 11:30 pm
by smogfalls
well... a few days later and the problem now seems to have gone away. I took the advice on re-heating the joints and I totally re-did the one's around the resistors, and it seems to have fixed the problem.
Thanks so much for all the help, it's greatly appreciated. It's awesome to have a portal to knowledge sitting here in my bedroom!
Thanks again,
Xan :)
