Fuzz Sound volume?
- Sk10
Fuzz Sound volume?
Yesterday i used my fuzz sound for the first time during a rehearsal.
I love the sound, character and versatility of this huge box, but I have one small problem:
The amount of volume on tap isn't that huge as described in the reviews and the captain's description. I only seem to reach unity gain at 3 o'clock. I don't think it's supposed to be like this.
When compared to my Meathead standard, the fuzz sound at full tilt is only as loud as the MH at 12 or 1 o'clock...
My testing gear:
Jazzmaster with SD quarterpounder PU's
Fender Strat with fairly low output PU's
through a London city DEA70 (an old plexi clone with a huge amount of headroom...)
What is wrong?
My testing gear:
What is wrong?
- imlikeajungle
- kb892
Re: Fuzz Sound volume?
that's how i remember the one sickle let me borrow.imlikeajungle wrote:Mine reaches unity gain at 9 o'clock...
- controller700
Like the said:
"Mojo of the MKIII, the base tone and clarity of a MKIV and a Buzzaround and the go fuck yourself volume of a Big Muff."
So when it is even louder then we speak of a "I fucked a Big Muff" amount of volume. Right?
I don't know what the hell it does, but it's definitely doing it!!
- Sk10
I just send him a pm...Sickle wrote:I guess the Captain will need to weigh in on this.
This evening I had another rehearsal with the Fuzz Sound and I still didn't have that "go fuck yourself" amount of volume.
I hope the Captain can help me...
- Sk10
How does my box sound? Great, apart from the lack of volume...
although I never played an mk3 or derivate before, so I can't make a real comparison...
but the Treble 'n' Bass is the best tone control evah
and I love the distortion characteristics when playing low downtuned riffs....'
Okay, so....
Do you get the same results on both of those geetars?
Have you tried the pedal with another amp?...if so, does it behave the same?
Is the pedal offering up any amount of boost above unity?
The Meathead is a totally different animal. It will be louder than the MKIII though the MKIII is a loud pedal for its circuit type. The Meathead is a high gain silicon fuzz tuned for one purpose only. Where as the MKIII is a germanium fuzz box tuned for flexibility. The D*A*M MKIII has at least twice the volume of a stock un-modified MKIII or MKIV. A vintage stock MKIII/MKIV will struggle to reach unity with most medium to high output pick-ups.
The volume boosting capabilities of fuzz pedals can vary quite a lot depending on geetar and amp type. For example I can achieve unity with a vintage voiced Stratocaster at approx 11-12 o'clock. If I use my 70's SG loaded with the P90, which is a hella loud guitar, I reach unity at 3 o'clock. With that guitar I usually run the MKIII flat out.
- Sk10
Idd, aprox the same results on both guitars.The Captain wrote:Okay, so....
I haven't tried it with a lopt of different amps, only my DIY 18watter (not much headroom) and some virtual amps on my PC.
I'll try to test it with a few other amps the next few days...
The pedal is idd offering a little amount of boost, but not as much as I expected/hoped for...
Would it be useful to make a stright recording guitar > Fuzz Sound > PC (without fx or vst amps) and post it here?
Yeah I know, but I did the comparison because the allmighty meathead is a widespread pedal on this board...The Captain wrote: The Meathead is a totally different animal. It will be louder than the MKIII though the MKIII is a loud pedal for its circuit type. The Meathead is a high gain silicon fuzz tuned for one purpose only. Where as the MKIII is a germanium fuzz box tuned for flexibility. The D*A*M MKIII has at least twice the volume of a stock un-modified MKIII or MKIV. A vintage stock MKIII/MKIV will struggle to reach unity with most medium to high output pick-ups.
Is the 18watter the only amp you have used it with?Sk10 wrote: ...only my DIY 18watter (not much headroom) and some virtual amps on my PC.
Yeah its worth a shot....it if ain't too much messing around for you.Sk10 wrote:Would it be useful to make a stright recording guitar > Fuzz Sound > PC (without fx or vst amps) and post it here?
- Sk10
The Captain wrote:Is the 18watter the only amp you have used it with?Sk10 wrote: ...only my DIY 18watter (not much headroom) and some virtual amps on my PC.
nope, my main amp is the aforementioned London City (Plexi Clone): it has a huge amount of headroom, so that shouldn't be the problem. I tried it in the LO & HI input.
I'll do that the tonight when I'm home...The Captain wrote:Yeah its worth a shot....it if ain't too much messing around for you.Sk10 wrote:Would it be useful to make a stright recording guitar > Fuzz Sound > PC (without fx or vst amps) and post it here?
