Show off your builds!
Re: Show off your builds!
You're the best, Tone!
^ My balls shift far more often than I'd like these days. Also, pedal looks ace!
- fernieite
That is a thing of beauty! (Inside and out)Dr Tony Balls wrote: ↑Sat Jul 03, 2021 2:22 pm Someone found me specifically wanting a Deluxe Memory Man on a Madbean board and form factor, so I obliged, despite my hatred of board mounted pots.
Dr Tony Balls wrote: ↑Fri Jul 16, 2021 3:06 pm Balls G-50. This one was commissioned to the exact Marshall 2204 circuit specs.
Just wait....there's a cooler one getting posted in a bit.
also Winona...
also Winona...
Amp #2 for the day!
Balls VIP-40. The VIP is for Vox/Plexi and is a sort of taking a JTM/JMP/5F6A approach to the AC-30 TB. It's kinda like an AC-30 except both brilliant and normal channels are "top-boost-ed" and it has a linked input like a jumpered plexi. Separate normal and brilliant volume controls let you blend the two channels as desired. No Vox-style cut control because its irrelevant in this format. Cathode biased and no negative feedback to retain that Vox feel. This is a 40 watt version using 2 EL34s. Sounds killer and super fun to play.
