- Arcane
- blunder
New neck for the Blunderbird. Been wanting a maple neck for this build for awhile now. Found this no name strat neck for $40 in a local shop.
Still need to do a little fretwork and will probably cut a new nut for it, but it plays surprisingly well as is.
You only like it because it looks like a Tele, Tony.
What's the neck pup in there, blunder? Proper Firebird pups are some of my favourite pickups ever.
- blunder
Neck pickup is a Roadhouse Kingston, a Supro style single coil. Really great pickup. I was planning on doing a proper Firebird pickup but got such a good deal on this set, I couldn't pass them up. I'll eventually get a Firebird for it though. I can put this set in my other tele.
- Yggdrazil
I haven't shared on here since a long time...
Here's some pic of a custom Stone Skull I'm slowly building.
Instagram:@Stonefly_effects
- Lee
Wow how did you cut the enclosure so nice
- Lee
Is brook making some Vibes I believe I saw a pic recently anyone know any info?
- Yggdrazil
The trick to cut something straight, whatever the tool used, is to clamp (C shaped Vise-Grip or other) a straight edge the long of the line you want to cut. I used a dremmel with mini cutting disks. One side at a time. Then, I adjusted both sides with a file. In case you want to try yourself have in mind the lower screw holes have to be drilled deeper prior to cut then re-tap.
To give credit, John Lyons was the first one I personally saw doing something like that
- peps1
It's true!
And in the spirit of "What is on your workbench Tinkerers?" Here are the custom wound transformers!
